Ansible- How to add a TAG to NXOS L3 Interface
JagadeeshKannaiah
My host_vars file as follows.
loopbacks:
- { interface: loopback0, addr: 30.30.30.30, mask: 32, tag: 54321 }
- { interface: loopback1, addr: 10.200.200.22, mask: 32, tag: 54321 }
Tasks file as follows.
name: CONFIGURE INTERFACE IP ADDR
nxos_l3_interface:
name: "{{ item.interface }}"
ipv4: "{{ item.addr }}/{{ item.mask }}"
tag: "{{ item.tag }}"
I get error as tag not recognisable
qsnyder
I'm curious if, for whatever reason, the value is not being picked up as an integer.  Per the `nxos_l3_interface` docs, this must be an integer value -- but it may be being passed as a string.
You can debug the variable type using the commands referenced in this URL: https://docs.ansible.com/ansible/latest/playbook_guide/playbooks_filters.html#discovering-the-data-type
q.
qsnyder
For what its worth, I'm willing to bet this is actually the issue.
Based on this page: https://stackoverflow.com/questions/28234430/ansible-integer-variables-in-yaml
You may be able to do something like `"{{ item.tag | int }}"` to make sure that the integer filter is applied to the corresponding value supplied from the variable.
q.
JagadeeshKannaiah
Found out Ansible NXOS module I was using was not supporting many features. Solved the problem by upgrading Ansible NXOS module to 4.0.1.
Thank you!
This community is intended for developer topics around Data Center technology and products. If you are looking for a non-developer topic about Data Center, you might find additional information in the Data Center and Cloud community
