configuring traffic shapping (Limitations) on Nexus for users on VLAN
SHEREAZARSHAD
show policy-map interface eth 1/2 output
Global statistics status :   enabled
NOTE: Type qos policy-map configured on VLAN will take precedence
       over system-qos policy-map for traffic on the VLAN
Ethernet1/2
  Service-policy (queuing) output:   default-out-policy
    policy statistics status:   enabled
    Class-map (queuing):   class-default (match-any)
      Match: qos-group 0
      bandwidth percent 100
      queue dropped pkts : 0  current depth pkts: 0
      queue dropped bytes : 0  current depth bytes: 0
      queue transmit pkts: 0 queue transmit bytes: 0
      queue max depth pkts: 0 queue max depth bytes: 0
show policy-map POL-MAP-1502-QOS-TEST
  Type qos policy-maps
  policy-map type qos POL-MAP-1502-QOS-TEST
    class type qos CLS-MAP-1502-QOS-TEST
      police cir 50 mbps bc 200 ms conform transmit violate drop
      set dscp default
    class type qos class-default
      set qos-group 0
show class-map  CLS-MAP-1502-QOS-TEST
  Type qos class-maps
    class-map type qos match-all CLS-MAP-1502-QOS-TEST
      match access-group name ACL-1502-CIR-DOWN-TEST
Orbit# show access-lists
IPV4 ACL ACL-1502-CIR-DOWN-TEST
        10 permit ip 103.11.62.68/30 any
switch# sh running-config int eth 1/2
interface Ethernet1/2
  switchport mode trunk
  switchport trunk allowed vlan 1802
  service-policy type qos input POL-MAP-1502-QOS-TEST
We are configuring traffic shapping (Limitations) on Nexus for users on VLAN level but it did not capture packets and did not implemented properly. Can anyone guide what is missing in this.
0 Replies 0
