04-06-2022 03:10 AM
I am searching for Nexus 9336C-FX2. I wonder LACP/Etherchannel is supported on 100GE ports or not?
From the documents, I can see it is supported but I need confirmation.
Thank You
Peyman
Solved! Go to Solution.
04-06-2022 03:42 AM
LACP is independent of interface speed. So yes, it is supported on 100G ports.
Stay safe,
Sergiu
04-06-2022 03:42 AM
Stay safe,
Sergiu
04-06-2022 03:52 AM
Dear Sergiu
Thank you for the Answer.
