vPC Port Channel Load Balancing Issue – Inconsistent Output Interface
elahe
Dear community members,
I have a pair of switches configured as a single Port Channel using vPC. However, I am facing an issue where packets from the same flow (same source/destination IP and port) arriving at each switch are being forwarded through different output interfaces while the configuration is consistent (load balancing by src-dst ip-l4port with symmetric option and a same rotate value). For example:
  • Switch 1 forwards the traffic with same ip and port via Ethernet1
  • Switch 2 forwards the traffic with same ip and port via Ethernet3
This behavior is not desirable in my scenario. I need each flow, even if its packets arrive at different switches from outside of my network, to always exit through the same interface to ensure a consistent path within my network.
Since both switches use the same PO hashing algorithm (ip-l4port with the same rotate value), I suspect the port-channel internal dynamic load balancing might be influencing this behavior but I could not find any documentation on it. Could this be the root cause? Is there anyway I can ensure that each flow follows a single egress path? (I tried fixed hash distribution too. It could not solve the issue.)
Any guidance or best practices for handling this situation would be greatly appreciated.
balaji.bandi
Is this vPC you are mentioning between switches vPC or end device?
What is an end device? Does this end device also do a matching algorithm?
Check some best practices and suggestions :
https://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/sw/design/vpc_design/vpc_best_practices_design_guide.pdf
BB
Its between switches
