Bookmark
Subscribe
932
Cisco ACI Nexus-as-code epg VPC static path
stelios_1911
Hi all,
I'm new to nac, do you know how to configure epg static port using VPC? Could you provide an example?
I search everywhere without any success, the NAC documentation does not provide one.
Thank you.
          endpoint_groups:
            - name: vlan-10
              bridge_domain: vlan-10
              physical_domains:
                - phys
              static_ports:
                - channel: vpc-to-core
                  node_id: 101
                  node2_id: 102
                  vlan: 10
Is your VPC and are those nodes defined? Also check indentation and optionally use the yaml extension in visual studio code to verify.
6 Replies 6
robvand
stelios_1911
Hi robvand,
Thank you for the reply, it is not clear  how to configure it, could you please provide an example? My code below
apic:
  tenants:
    - name: prod
      application_profiles:
        - name: ap_prod
          endpoint_groups:
            - name: epg_Vlan02
              description: Test
              bridge_domain: bd_Vlan02
              physical_domains:
                - prod_phy_domain
              static_ports:
                - node_id: 1311
                  vlan: 2
                  pod_id: 1
                  port: 1
                  mode: regular
                - node_id: 1312
                  vlan: 2
                  pod_id: 1
                  port: 1
                  mode: regular
This assumes that the vPC is defined as "vpc-to-core"
        endpoint_groups:
            - name: vlan-10
              physical_domains:
                - phys
              static_ports:
                  vlan: 10
doesn't need the node_id? I think I'm doing something wrong, below the code and error from pipeline:
apic:
  tenants:
    - name: prod
        - name: ap_prod
          endpoint_groups:
            - name: epg_Vlan02
              description: TelDir_10.0.114.0_24
              physical_domains:
                - prod_phy_domain
              static_ports:
                - node_id: 1311
                  vlan: 2
                  port: 1
                  channel: vpc_SPR-ESXHOS-PX02_data
                  mode: regular
                - node_id: 1312
                  vlan: 2
                  port: 1
                  mode: regular
          endpoint_groups:
            - name: vlan-10
              physical_domains:
                - phys
              static_ports:
                  node_id: 101
                  node2_id: 102
                  vlan: 10
stelios_1911
Oh my god is working! Thousand thanks robvand
I was  struggling for two days, I don't know why there is such a luck of documentation, there is one comprehensive example for nac and that's it. Not even AI tools helped.
Below the successful code:
static_ports:
                - node_id: 1311
                  node2_id: 1312
                  vlan: 2
                  mode: regular
