06-29-2017 02:33 PM - edited 03-01-2019 03:54 AM
Hello team, which NED should I use for provisioning on a CBR8?
Best regards
Jose
Solved! Go to Solution.
06-29-2017 09:26 PM
I believe CBR8 is IOS-XE based. So the cisco-ios NED is the one that needs to be used.
If use-cases/configuration required is not currently modeled in the NED then a ticket can be raised and the model extended.
06-29-2017 09:26 PM
10-23-2019 10:26 AM
Has someone verified or validated this works, can it be proposed to a customer
10-23-2019 10:35 AM
Yes, we have customers automating cbr8s with NSO
