foreach in template
ian.scheidler1
Level 4
Level 4
I have a problem which I really dont understand. In one case it works, in another it doesnt.
Let's start with what works:
YANG:
leaf-list iphelper {
       type inet:ipv4-address {
The Leaf List is filled with data from WebUI:
Template:
<ip>
    <address>
        <primary>
            <address>{/gw_ip}</address>
            <mask>{/subnetmask_usernet}</mask>
        </primary>
    </address>
    <?foreach {/iphelper}?>
        <helper-address><!--for each, input list-->
            <helper-address-list>
	        <address>{/iphelper}</address>
	    </helper-address-list>
            </helper-address>
     <?end?>
This correctly generates multiple iphelper entries in the config for every item in the list. Like this:
interface Vlan975
 ip vrf forwarding db-sus-ri
 ip address 192.168.2.1 255.255.255.0
 ip helper-address 192.168.33.3
 ip helper-address 192.168.44.4
 ip helper-address 192.168.55.5
 no shutdown
 no autostate
exit
So far so good. This all works. :)
I am now trying to apply the same pattern to a List of IP prefixes:
YANG:
leaf-list prefixlist {
      type inet:ipv4-address { //TODO: type here should be inet:ipv4-prefix (e.g. xxx.xxx.xxx.xxx/xx)
Here is actually my first problem. If I use the inet:ipv4-prefix data type it is somehow impossible to fill the list from the WebUI (when i click on + an input field opens up and I can enter a prefix but when I click OK the input field closes but it just doesnt show up in the list in the WebUI). Haven't actually tried yet from CLI as customer wants the WebUI and I also believe it should be possible from both. Any ideas on this?
Template:
<ip>
<!-- ...here is some vrf config which I left out here... -->
<prefix-list><!--foreach seq 50--> <prefixes> <name>PL_{$vrf_name}_bgp2ebgp</name> <seq> <no>5</no> <permit> <ip>0.0.0.0/0</ip> </permit> </seq>
</prefixes> <prefixes> <name>PL_{$vrf_name}_ebgp2bgp</name> <seq> <no>5</no> <permit> <ip>10.242.0.0/16</ip> <le>30</le> </permit> </seq> <seq> <no>10</no> <permit> <ip>10.243.0.0/16</ip> <le>30</le> </permit> </seq> <seq> <no>15</no> <permit> <ip>10.244.0.0/16</ip> <le>30</le> </permit> </seq> <seq> <no>20</no> <permit> <ip>10.245.0.0/16</ip> <le>30</le> </permit> </seq> <seq> <no>25</no> <permit> <ip>10.246.0.0/16</ip> <le>30</le> </permit> </seq> <seq> <no>30</no> <permit> <ip>10.247.0.0/16</ip> <le>30</le> </permit> </seq> <seq> <no>35</no> <permit> <ip>10.248.0.0/16</ip> <le>30</le> </permit> </seq> <seq> <no>40</no> <permit> <ip>10.249.0.0/16</ip> <le>30</le> </permit> </seq> <seq> <no>45</no> <permit> <ip>10.250.0.0/16</ip> <le>30</le> </permit> </seq>
<?foreach {/prefixlist}?>
<seq>
<no>50</no>
<permit>
<ip>{/prefixlist}</ip>
<le>30</le>
</permit>
</seq>
<?end?> </prefixes> </prefix-list> </ip>
As you can hopefully see the prefix data up to line (<no>) 45 is static and everything after that should be added from the leaf list entries.
I get the following error:
Python cb_create error. Unknown error (66): DBS_VPN-template.xml:103 Expression '{/prefixlist}' resulted in an incompatible value '192.168.44.4192.168.55.5192.168.66.6' for /ncs:devices/device{IOSdev0}/config/ios:ip/prefix-list/prefixes{PL_db-sus-ri_ebgp2bgp}/seq{50}/permit/ip
I understand that NSO tries to apply the entire list (concatenated together) as one value, which doesn't work.
But why does this work for IP helper? And how else do I access the single items of the list otherwise?
2 Accepted Solutions
Doing the second bit in templates-only might not be that trivial, but can be done in python.
This can be part of your template:
<config-template xmlns="http://tail-f.com/ns/config/1.0">
  <devices xmlns="http://tail-f.com/ns/ncs">
    <device>
      <name>{/device}</name>
      <config>
        <interface xmlns="urn:ios">
          <Vlan>
            <name>975</name>
            <ip>
              <helper-address>
              </helper-address>
            </ip>
          </Vlan>
        </interface>
        <ip xmlns="urn:ios">
          <prefix-list>
            <prefixes>
              <name>PL_foo</name>
              <seq>
                <no>5</no>
                <permit>
                  <ip>1.1.1.1/32</ip>
                </permit>
              </seq>
              <seq>
                <no>{$SEQ}</no>
                <permit>
                  <ip>{$PREFIX}</ip>
                </permit>
              </seq>
            </prefixes>
          </prefix-list>
        </ip>
      </config>
    </device>
  </devices>
</config-template>
and this can be the python code to apply the template:
   @service.create
    def cb_create(self, tctx, root, service, proplist):
        self.log.info('Service create(service=', service._path, ')')
        vars = ncs.template.Variables()
        seq = 50
        for prefix in service.prefixlist:
            vars.add('SEQ', seq)
            vars.add('PREFIX', prefix + '/32')
            template = ncs.template.Template(service)
            template.apply('ian-template', vars)
            seq = seq + 10
It might have been cleaner to split the template into static part and dynamic part and only apply the dynamic part multiple times, but the result is the same.
Hi Ian,
I think, as you already discussed, you don't always need the foreach. The template will loop automatically. But if you want to explicitly loop, you can refer to current interation using current() or .
You could set a variable to store the counter. So something like:
<?set counter={0}?>
<seq>
  <no>{$counter}</no>
  <permit>
    <ip>{current()}</ip>
    <le>30</le>
  </permit>
  <?set counter={$counter + 5}?>
</seq>
<?end?>
7 Replies 7
yfherzog
On the helper address list, you're pushing configs into multiple list entries, as 'address' is a key in a list called helper-address-list.
On the second example, 'permit' is a container, so it can only take one value, and you provide it with the complete content of your list of prefixes.
You might want to create multiple entries of the 'seq' list, providing a running sequence to 'no' (currently you use 50 for all iterations).
Also, be careful when you use the '/' inside your templates (e.g. /prefixlist).
It actually resets the execution context in the template engine.
Use 'commit dry-run | debug template' to debug the process.
Finally, I tend to think that your first example will work even if you remove the foreach statement (give it a try).
Hi thanks.
OK I will try the first example without foreach and see if it works (from your explanatin I also believe it will work).
As for the second example
OK...I also need some sort of counter which increments in steps of 5. How can I have such a counter in the template (or rather in the foreach)?
And how do I tell NSO to only use the current entry of the leaf list in each iteration?
If you could provide me with a (small) code example I would be very grateful!
    <device>
      <config>
          <Vlan>
            <name>975</name>
            <ip>
              <helper-address>
              </helper-address>
            </ip>
          </Vlan>
        </interface>
          <prefix-list>
            <prefixes>
              <name>PL_foo</name>
              <seq>
                <no>5</no>
                <permit>
                  <ip>1.1.1.1/32</ip>
                </permit>
              </seq>
              <seq>
                <no>{$SEQ}</no>
                <permit>
                  <ip>{$PREFIX}</ip>
                </permit>
              </seq>
            </prefixes>
          </prefix-list>
        </ip>
      </config>
    </device>
  </devices>
</config-template>
   @service.create
        seq = 50
            seq = seq + 10
How would you do the python for loop to a yang 'list' with few leaf instead of 'leaf-list' as mentioned in your example?
For example :
list prefixlist {
      key prefix;
      leaf prefix {
        type string;
      leaf id {
        type string;
      leaf length {
        type string;
Something like that:
           self.log.info('DEBUG:(interface=', prefix, ')')
           self.log.info('DEBUG:(id=', service.prefixlist.id, ')')
           self.log.info('DEBUG:(length=', service.prefixlist.length, ')')
I can't make it work.
Not sure exactly what's not working, but your prints should look something like this:
           self.log.info('DEBUG:(interface=', prefix.prefix, ')')
           self.log.info('DEBUG:(id=', prefix.id, ')')
           self.log.info('DEBUG:(length=', prefix.length, ')')
Thanks a lot it works now! I see my mistake now.
Hi Ian,
<?set counter={0}?>
<seq>
  <no>{$counter}</no>
  <permit>
    <le>30</le>
  </permit>
</seq>
<?end?>
