How to set CLI prompt colour?
u.avsec
Hey.
I'm trying to change NSO CLI prompt colour. I'm using this thread as help: https://stackoverflow.com/questions/5947742/how-to-change-the-output-color-of-echo-in-linux
In my linux shell this prints following text green:
printf '\033[32m'
 echo $TERM prints 'xterm'
I tried the following in ncs.conf (ncs --reload applied):
<cli>
    <c-prompt1>\033[32m\u@ncs#\033[0m </c-prompt1>
    <c-prompt2>\[\033[32m\]\u@ncs(\m)#\[\033[m\] </c-prompt2>
</cli>
Nothing, CLI prints 033[ and stuff instead of colours. I tried with 'e' instead of '033' too. No music.
Tail-f, please help
6 Replies 6
vleijon
This command works for me: "\e[38;5;9mNSO\e[0m \u@\h#”
I don't have such luck:
I used your example, the user and hostname flags work, but colour stuff not.
This is on Windows Terminal, I tried with putty just in case, to same result.
It works in the CLI, which is where I always do it:
Not sure if you need to do something special in ncs.conf.
That was it, I was setting it up in ncs.conf and it just doesn't want to work.
How do I persist the prompt change done via CLI though?
You can set it as config under user admin session prompt1, but I am not entirely sure what the correct escaping would look like, maybe someone else knows.
I tried combinations of what I found as an example in man pages:
<prompt1>\[&#x1b;]0;\u@\h&#x07;\]\u@\h&gt; </prompt1>
This this particular expression works. When I tried to apply it for colour coding it doesn't. Either because I might be misreading the example or because it simply doesn't want to do colours.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
