load-native-config results in "not implemented" error
allenc
I am trying out the new load-native-config command under NSO 5.1.1. When I try it, I get errors like this:
admin@ncs(config)# devices device ios0 load-native-config data "hostname asd"
Error: External error in the NED implementation for device ios0: not implemented
admin@ncs(config)# devices device dell0 load-native-config file test.ftos mode replace verbose
Error: External error in the NED implementation for device dell0: not implemented
ios0 and dell0 are both netsims. ios0 was created with the sample cisco-ios-cli-3.8 NED that came with NSO 5.1.1. dell0 was created with the new Dell FTOS NED.
What am I doing wrong?
-Allen
gmuloche
Hello the NED that comes as example are quite old - if you look at the CHANGES.txt for cisco-ios-cli-3.8
  1 cisco-ios v3.8.0 [March 16, 2015]
  2 =================================
  4 Enhancements:
  6   - Support for NCS-3.4.
The support for cisco-ios NED for load-native config was added later:
  393 cisco-ios v6.20.3 [2019-04-05]
  394 ==============================
  402
  403   - Added support for NSO 5.1 config CLI command 'load-native-config' which
  404      can be used to load and convert device config into ncs_cli config mode:
  405      admin@ncs(config)# devices device <device> load-native-config data|file
  406     Note: Even with netsim the data is parsed as it was in native IOS format.
  407     (CISCOIOS-1360)
I assume it is the same explanation for the Dell NED.
gmuloche
  4 Enhancements:
  402
  407     (CISCOIOS-1360)
Thanks for the reply.  I didn't know that additional work had to be done to add support for load-native-config.  The Dell NED is brand new, but they probably didn't add support for it, either.  I'll open a TAC case to request it.
-Allen
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
