11-17-2017 03:29 PM - edited 03-01-2019 04:02 AM
I am looking for recommendations on how to deploy NSO with the following requirements:
< 30k total devices
1-8 globally located clusters of devices (co-location facilities)
Deployment of NSO in one or more of the 1-8 locations
Single API point for deploying services across all devices/locations
Ability to still deploy/modify services even if 1 of the facilities used as a potential control point (NSO) goes offline.
What are the service designs supported by the recommended deployment.
I have not been able to find documentation to base my decisions.
Thanks in advance.
11-20-2017 01:12 AM
Hi there,
Checkout the LSA documentation that comes with the NSO installation (for example nso_lsa-4.5.pdf). Also check out "deployment_guide.pdf" that comes bundled with the tailf-hcc package (describes the NSO HA framework).
Bilal.
11-21-2017 11:45 AM
Thanks Bilal,
I have read both of those documents which covers how to deploy NSO and how to take advantage of LSA and the deployment model needed when using LSA. What I think is missing is when to use the various deployment options.
Questions I need to answer are:
Johan
11-24-2017 01:23 AM
All good questions. I know various folks have discussed these but don't think there is a guide as such. The information is available but dispersed. Perhaps we can request the Cisco-AS team to do a "guide" write-up, given that they have done majority of the real-life deployments. Also engineering have done some simulations too.
I've added my thoughts below.
When it comes to scale, the dimensions to consider are:
1.
Memory as all configs are stored in the in-memory CDB
- The number of devices and the average size of the device configuration
- The number of service instances and the average size of the service configuration
- Mark this up to account for metadata (back-pointers, etc). That should give the required memory.
2.
CPU processing
The incoming rate of Move-Add-Change (MAC) requests
- The complexity of service mapping logic for each of the service-types
- Transactional approach or asycn commit-queues
- I've seen some testing done 3+ years back with NETSIMs and commit-queue. With CPUs back then the throughput was around 14 changes per seconds for a VPN like service
- The service types could be split across multiple NSOs (CFS-NODEs) to spread the incoming MACs.
I guess every scenario is so different and one sizing may not work for all. BTW, I've heard the rule-of-thumb of scale-out with LSA with 20k-30k devices per NSO-RFS-instance.
