N9K-C93180LC-EX SFP compatibility
drkershner
https://tmgmatrix.cisco.com/?si=C93180LC-EX
 Adding servers to the N9K-C93180LC-EX. Need 10G connectivity and see SFP-10G-SR on compatibility matrix but issue is it looks like this switch only takes QSFPs?
 Is there an adapter required to make the SPFs work?
Pavel Tarakanov
Cisco Nexus 93180LC-EX
Up to 32 x 40/50-Gbps QSFP+ ports OR 18 x 100-Gbps QSFP28 ports
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/datasheet-c78-742283.html
QSFP Ports, QSA (CVR-QSFP-SFP10G) required.
Mode 1: 28 x 40G + 4 x 40G/100G (If top port is configured as 10G or 1G using QSA adapter; the bottom port also needs to be 10G or 1G to match the speed).
Mode 2: 24 x 40G + 6 x 40G/100G (If top port is configured as 10G or 1G using QSA adapter; the bottom port also needs to be 10G or 1G to SFP match the speed). Port 26 and 28 are disabled.
Mode 3: 18 x 40G/100G (QSA is supported on all the 18 ports.)
Pavel Tarakanov
