6608 T1 port as network side?
d.kettler
I am trying to configure my 6608 T1 port as the network side. I have selected the Protocol Side to be Network but after the port registers I check the Device Configuration by clicking on the IP address of the port, and it states it is protocol - user even though Network is clearly configured. Can this port be configured as network side and if so what I am doing wrong?
Dave
jamie.moss
you can do this as we are using 6608 T1 cards to connect between a Nortel PBX and our Call Manager environment.
What version of Call Manager are you using?
I've just checked our Call Manager cluster and I do see protocol Network when browsing the card using HTTP.
This could be a load issue or I have seen configuration correct in call Manager and not work.
Have you tried reloading the 6608 card or if you can't do that, have you tried reloading the port - not through Call Manager but through the 6500 series switch using CATOS commands.
d.kettler
TAC had me hard reset the card, not from Call Manager and this fixed the problem.
Thanks for the reply
Dave
