7940/7960 Custom Color Cases/Handsets
calmichael
I seem to remember one of our past Cisco SE's that
mentioned a third party vendor that was manufacturing
either custom color cases (replacing the stock dark
gray with silver bezel plastic case) or the handset
itself.
I remember implementing a site where we had obtained
red handsets for the "SRST enabled" handsets; but
am unable to find where those were procured from.
Of course we can always raid a Fry's or Radio Shack
for red handset cables instead. . . (grin)
But does anyone know of a current vendor that produces
these for Cisco IP Phone sets?
--- Thanks ---
6 Replies 6
dweiner
Red sticker set from Overlay Pro -
http://www.overlaypro.com/store/find.lasso?-database=products.fp3&-layout=www_products&-sortField=Name&-sortOrder=ascending&-logicalOperator=OR&-op=cn&Name=8820&-op=cn&Description=8820&-maxRecords=1&-token=find&-search&-response=detail.lasso
To avoid the url wrap challenge, just go to:
and search on Cisco
You can couple this with a push to talk handset from Walker Technologies - original handset modified with a PTT button.
Could you elaborate on the PTT handset from Walker. Exactly what does it do? I tried getting an answer from Walker and they simply replied - it works with Cisco. Their website said something about 'secure' communications.
Essentially the 'push-to-talk' button disconnects the handset mic when it's not being pressed. This really is just a forced mute function which means that background conversations (or noise) don't get picked up. Very useful if you work in a secure environment, have lots of equipment around, or just really noisy co-workers.
OK - Thanks. When they talked about secure, I thought it worked with some ACS or key server in the background and encrypted the link.
Thanks for explaining that. I might actually have a need for that.
This was what we were looking for, though the other
manufacturer that I remember also had other safety
colors available.
Out of curiousity, what is the link for the Walker
PTT product? I tried googling for it and came up
with a Walker Technologies that makes phone sets
with amplifiers - not just handsets.
