7960 Handset Problem (can only listen/talk on speaker)
kkkkhine
Whenever I start a new call or pick up a call, I can only listen/talk to speaker phone.
The handset is working on other 7960.
I tried with CallManager and also asterisk SIP PBX.
Any idea?
Thanks ...
- Kyaw
8 Replies 8
Pabloduarte
Sounds like a bad hookswitch to me.
We've had several of bad hookswitches on our sets.
Look at the display on the phone to see if it changes
to off Hook status whenever you pick up the handset.
I can tell you how to fix it if it is the hookswitch
Let me know.
Pablo
Hi Pablo,
When I pick up the handset, the icon on the display does not change.
It only changes when I click on speaker phone.
Sounds like the problem you know.
Thanks a lot.
- Joe
You may want to check out this document regarding the 7900 series hookswitch:
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a00801c0810.shtml
I cannot tell you how many 7960's of ours this has happened to. Thanks so much for posting the link to that article.
TMH
Manny thanks also for this great post :)
I start to belive that is something wrong in my cnf file for Asterisk :)
Manny thanks :)
Great tips & tricks
According to an account manager, its a new feature in Cisco 7912. Dont laugh, I´m not kidding.
Cisco present this seriously as a new, great feature.
greetings, sebbo
You can clean your switch and it might help
You can keep pressing down and letting go of the switch with your finger for 15-20 times at a constant speed, this will clean up the contacts for the switch, you can also use some water and a cloth to clean the switch.
I have also seen the handset go bad.
Almost 4 years betwen a post and another. I believe this is a record.
