after CM upgrade, Mesage Waiting Light will not be lit
maryclegg
Whenever we do a CM upgrade, we will always have one phone that receives VM but no MWL. It is usually several days later when the user realizes it. It is always a different extension. What causes this and what can we do to prevent this problem?
Rob Huffman
Hi Mary,
Long time my friend! Hope all is well.
This is very common when doing any significant changes on CUCM (like an upgrade). The way we usually mitigate these type of issues is to run a MWI Re-sync after the changes are done (usually the last step).
In Unity Connection go to Telephony Integrations - Phone System - Click the Run Button for Synchronize All MWIs on This Phone System.
This is available in Unity versions as well :)
Hope this helps!
Rob
Rob Huffman
Hi Mary,
Hope this helps!
Rob
Thanks, Rob. I knew you would know the answer. Hope all is well with you also.
Rob, can I do that resync now during regular business hours while all the users are here or will it cause interruptions?
Hi Mary,
Life is really great here :) I would run the MWI re-sync afterhours.
Cheers!
Rob
