05-07-2004 06:18 PM - edited 03-15-2019 02:51 AM
Hi Guys!
I have a 2651xm router with an aim-atm-voice-30 module and a wic-2mft-t1 card. I am trying to configure pri on the first controller for my access to PSTN, and channel group for data connection to a remote site on the second controller. I manage to configure the pri , but when I try to to the same for the channel group I get this message:
2650_Bradenton(config)#controll t1 0/0
2650_Bradenton(config-controller)#pri-group timeslots 1-9
2650_Bradenton(config-controller)#controller t1 0/1
2650_Bradenton(config-controller)#chan
2650_Bradenton(config-controller)#channel-group 0 tim 1-24 speed 64 ?
<cr>
%The MFT-VWIC module is already connected to AIM slot,
cannot create Channel groups using onboard SCC.
Please reconfigure channel-group command with"aim #aim-slot" keyword
%Insufficient resources to create channel group
I don't have to say that I don't have the aim command at the end if the channel group line.
Has anyone seen this before? Cisco's page is like always full of stuff that we don't need, and misses explanations for real problems.
Dragi
05-07-2004 11:46 PM
I think you are not having the right IOS. Starting with 12.2T train IOS you do have support for the aim slot command option in the channel-group command.
05-08-2004 04:46 AM
Dragi, what version of IOS are you using?
You'll need at a minimum 12.2(15)T.
Previous to this release, this was not supported.
Dan
05-08-2004 06:42 AM
The IOS versions I have tried so far were SP, Advanced IP Services and IP Voice, all either 12.3.4T4 or 12.3.7T1. Do I need Plus version?
Dragi
05-09-2004 04:52 AM
Dragi, do a 'show ver' and/or 'sh diag'. Does the system show an AIM-ATM-VOICE-30 or an AIM-VOICE-30?
If you have an AIM-VOICE-30, it will only support only one kind of group!
If it shows, AIM-ATM-VOICE-30, would it be permissable to test 12.2(15)T on this router as a baseline or is it in production and/or require the other IOS release?
The AIM-ATM-VOICE-30 is the only module that supports a combination of DS0, PRI and channel groups
on the same T1/E1 (ver. 12.2(15) T and later).
Dan
05-10-2004 04:58 AM
Dan,
I have the voice-30 module, and I've tried 12.2.15t. What I've figured out is that after one's applied any config combination on those two controllers, if he/she wants to change it, the config needs to be deleted, and the router rebooted in order to be able to accept any changes on those controllers. Is this the way it's supposed to be?
Dragi
05-14-2004 07:52 AM
I have the exact same issue on a 2651, my snipped show ver and diag are below. How exactly can I tell which AIM this is?
Trouble#sho ver
"flash:c2600-is-mz.122-15.zj3.bin"
cisco 2651XM (MPC860P) processor (revision 0x200) with 124928K/6144K bytes of memory.
Primary Rate ISDN software, Version 1.1.
24 Serial network interface(s)
2 Channelized T1/PRI port(s)
1 ATM AIM(s)
Trouble#sho diag
ATM AIM: 0
Voice AIM with 4 DSPs
Hardware Revision : 1.0
Top Assy. Part Number : 800-13259-03
Board Revision : A0
Deviation Number : 6718-7
Fab Version : 02
PCB Serial Number : JAE08071PXY
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 02 7C 41 01 00 C0 46 03 20 00 33 CB 03
0x10: 42 41 30 80 1A 3E 00 07 02 02 C1 8B 4A 41 45 30
0x20: 38 30 37 31 50 58 59 03 00 81 00 00 00 00 04 00
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
05-14-2004 09:01 AM
You have an AIM-ATM-Voice-30 module. The way I was able to change the config on the controllers is to erase it, reboot the router and then configure what I need. I guess this has to do something with the way clocking is implemented on this aim. As you probably aleady know it, Cisco engineers have not been too helpful with this issue. I got one reply from one of them, and that's where it stopped. TAC's level has really gone down, that is the only thing I can tell you...
Dragi
