I have problems with call setup in following H323 configuration using cisco 3745 GW:
PBX-(E1,ISDN)-Gateway_C3745_IOS.12.3.3e-GK_C3725-Gateway_c3660-(E1,QSIG)-PBX.
Everything work fine except some calls from phones that are connected to the left PBX. 10-15 % of calls are disconnected with cause code 47 - No resource available, unspecified. Calls are rejected unpredictably w/o making ARQ request to GK.
deb isdn q931 output:
ISDN Se1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0xDE92
Cause i = 0x80AF - Resource unavailable, unspecified
sh h323 gateway cause output:
CAUSE CODE STATISTICS AT 01:47:22
DISC CAUSE CODE FROM OTHER PEER FROM H323 PEER
0 0 2
16 normal call clearing 27 41
27 user busy (17) 17 0
34 no circuit (34) 0 2
47 no resource (47) 0 11
sh run
voice-card 1
codec complexity high
dspfarm
isdn switch-type primary-net5
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-31
Thanks for support.
Andrei Gromov
