can not ping aim-cue
serdarb
Any idea why I cannot ping the AIM-CUE ?
thanks
interface Service-Engine0/0
ip address 10.224.32.17 255.255.255.252
service-module ip address 10.224.32.18 255.255.255.252
service-module ip default-gateway 10.224.32.17
#ping 10.224.32.18
Sending 5, 100-byte ICMP Echos to 10.224.32.18, timeout is 2 seconds:
Success rate is 0 percent (0/5)
9 Replies 9
paolo bevilacqua
Check that module is running, via service-module session.
I can make session to module, and also it says up when I check it.
When is session, check with the show commands, thta the addresses are right.
Check to have an ip route to the service module ip address with subnet /32 and output interface service engine
thanks & best Regards
Hytham Hadad
That should not be necessary, because a dedicated subnet is being used, not unnumbered.
However, I agree that unnumbered using a voice VLAN address is a better choice.
I reloaded the module and it is ok now :) interesting...
Why you should ?
Either use explicit or unnmbered, as recommended by configuration guides.
Hi Paolo
thanks for our note
You are welcome, please remember to rate useful posts with the scrollbox below.
