04-07-2006 12:56 AM - edited 03-13-2019 12:49 PM
I have an issue that when a user is on a call and a further call comes in this is not being immeadiately bounced to the next free extension even though I have timeouts busy 0 set. Config is as below any ideas anyone?
pilot 706772
list 1009, 1007, 1006, 1004
final 8011
timeouts interdigit 5
timeouts busy 0
timeouts ringing 10
04-12-2006 08:15 AM
You might want to see if this link helps...
04-12-2006 08:25 AM
I'm guessing that you have dual-line ephone DNs configured? What is likely happening is that the call is hitting the second line on the DN.
Try configuring the 'huntstop channel' command under the ephones-dns in the hunt group.
Aaron
