Changing Soft Keys
kgroves42
Level 3
Level 3
Is there a way to change the softkeys so when you pick up a 7960 or 7940 phone it will display "pickup" instead of say "hang up"?
Ken Groves
mimckee
To my knowledge there is not a supported way to change the softkeys yet. I think I have heard talk of it in future versions but can't remember if that is the next major version or the one after the next major version.
Hope this helps,
-Mckee
dgoodwin
In the next version of CallManager after 3.2, there will be a way to change where the softkeys appear, but as far as I know, no supported way to change the text of the softkeys.
