Cisco 2811 - NM-HDV2-2PORT T1 module configuration
cwyeager
Unable to get ISDN PRI D-channel to stay in service when the CONTROLLER T1 is set for - "service mgcp"
XXXXXX_Voice_Gateway#sho run
Building configuration...
Current configuration : 2159 bytes
version 12.4
service config
hostname XXXX_Voice_Gateway
boot-start-marker
boot system flash c2800nm-adventerprisek9-mz.124-1.bin
boot-end-marker
card type t1 1 1
logging buffered 51200 warnings
enable secret xxxx
no aaa new-model
resource policy
network-clock-participate slot 1
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip domain name XXXX.com
no ip ips deny-action ips-interface
isdn switch-type primary-ni
voice-card 1
dspfarm
username XXXX privilege 15 password 0 XXXX
controller T1 1/0
framing esf
linecode b8zs
pri-group timeslots 1-24 <<-- (I had this set to "service mgcp")
controller T1 1/1
framing esf
linecode b8zs
interface Tunnel1
no ip address
interface FastEthernet0/0
description CMtoGateway
ip address 10.151.XX.XX 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0:23
no ip address
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
interface Serial1/1:23
no ip address
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 10.151.XX.XX
ip http server
ip http authentication local
no ip http secure-server
control-plane
voice-port 1/0:23
voice-port 1/1:23
ccm-manager redundant-host 10.151.XX.XX
ccm-manager mgcp
ccm-manager music-on-hold
mgcp
mgcp call-agent 10.151.XX.XX service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp timer receive-rtcp
mgcp sdp simple
no mgcp explicit hookstate
mgcp profile default
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
scheduler allocate 20000 1000
end
-----------------------------------#show isdn status
Global ISDN Switchtype = primary-ni
ISDN Serial1/0:23 interface
dsl 0, interface ISDN Switchtype = primary-ni
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x807FFFFF
Number of L2 Discards = 0, L2 Session ID = 2
ISDN Serial1/1:23 interface
dsl 1, interface ISDN Switchtype = primary-ni
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
Active dsl 1 CCBs = 0
The Free Channel Mask: 0x00000000
Number of L2 Discards = 0, L2 Session ID = 1
Total Allocated ISDN CCBs = 0
5 Replies 5
mparekh
Level 3
Level 3
network-clock-select
Try these two commands.
Should the controllers be set back to "service mgcp"
Try to set the controller t1 back to service mgcp, "pri-group timeslots 1-24 service mgcp"
Let me know how it goes.
Found out after some digging, that the problem was not with the MGCP config in the router, but the FQDN in the CallManager. Reconciled the differnce, all returned to service.
It is always the little things.....
tmaurello_2
If you want to use MGCP and you want to use the ccm-manager configuration, you will need to modify the d-channel as well.
First, put the service mgcp back into the controller configurations.
Next, in the d-channel config Serial 0/0:23 and Serial 0/1:23, add the following line:
"isdn bind-l3 ccm-manager"
This backhauls the d-channel back to the CallManager (MGCP only!).
I also like to use these options, but they are not required.
ccm-manager config-server CALLMANAGER_IP_ADDRESS
ccm-manager config
