CIsco 2821 gateway not taking voice related commands
gnanavel.ns
Dear all,
I am trying to setup a Cisco 2821 router as a voice gateway to connect to PSTN (ISDN PRI). I am seeing an issue wherein the router CLI Not taking many of the voice related commands.
1) Scenario 1
Hardware config of the router-
Cisco 2821 with NM-HDV / VWIC-1MFT-E1
PVDM-12 - 3 nos
IOS- c2800nm-spservicesk9-mz.124-12c.bin
Router not taking 'card type E1' and ISDN related commands such as ISDN switch type, interface Serial 1/0/0:15, voice-port 1/0/0:15.
2) Scenario 2
Cisco 2821 with VWIC-1MFT-T1/E1
There are no PVDMs.
IOS- c2800nm-spservicesk9-mz.124-15.T12
Router not taking 'voice-port' command and in dial-peer voice pots mode, the 'port' command is not shown at all.
ANy clues as to why this is happening?
Thanks for your time.
Gnan.
ronpatel
Level 8
Level 8
HI
Send us Sh tech of the router .
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
paolo bevilacqua
You need PVDM to enable voice port.
Note: sending show tech is not needed in elementary cases like this.
As per original post, PVDM-12 - 3 nos. So Sh tech will give all the details about the PVDm status and the configuration.
Ronak Patel
Again: it is not needed to  produce such an huge output for such an elementary case. e,g, "Show inventory" is enough.
