11-03-2005 05:54 AM - edited 03-15-2019 03:48 AM
I have a CME installed in my office. I have a couple of users who will be working out of another office across town. We have a VPN LAN-to-LAN link between the 2 locations. Can I use 7960 phones for the users at the temp location and get service from my CME?
11-03-2005 07:58 AM
That certainly is possible. You'll need to consider QoS. Is this a DSL/Cable link that you have no control of? You'll also need to consider 911. If a remote user dials 911 and the call goes out a gateway at your main office, then trucks will roll to the main office.
Hope this helps.
Brandon
11-03-2005 01:34 PM
I was aware of the issue concerning 911 but thanks for the reminder. You say its possible. Can I install a Pix firewall behind the ISP router; setup a VPN LAN-to-LAN and have my phones work?
11-03-2005 01:55 PM
Yes you can. I have used this configuration. My setup was with CallManager, but it will be very similar with CME.
Brandon
