Compatible Headsets for 7900 and 8800 Series
steigja
Level 3
Level 3
Hello All,
    I'am searching for a suitable compatible headset, wireless if possible.  It need sot be compatible with both the 7900 series and the 8800 series.  It also need to be able to function with jabber if a user is remote using there laptop.  Anyone have an experience with that solution?  Thanks
Jason
Deepak Rawat
You can go for either Plantronics or Jabra headsets which are well known to work good with Cisco IP Phones and are fully compatible.
Plantronics
http://www.plantronics.com/ca/compatibility-guide/#/search/
Jabra
http://www.jabra.ca/headsets-and-speakerphones/compatibilityguide#selectedProducts=[]
Deepak
Jaime Valencia
