difference between cisco 1760 and cisco 1760-V series routers
shekarb4u
What is the difference between cisco 1760 and cisco 1760-V series routers. Plz let me know in what scenarios these routers will be used.
Thanking you in advance
Shekar
with regards.
irisrios
Level 6
Level 6
The difference between a cisco 1760 and a 1760-v is that the -v version has more RAM and IP-PLUS software. And also usually the routers with -v version are voice ready routers. Its just packaging that differs, Otherwise both are same.
kerrow
Also, I believe the 1760-V has the DSP resources installed already, thus being voice ready.
startryst
DRAM:
1760========64MB
1760-V======96MB
IOS:
1760========Cisco IOS IP
1760-V======Cisco IOS IP/Voice Plus
DSP:
1760========None
1760-V======PVDM-256K-4
Data above is the exactly difference between Cisco 1760 and 1760-V.
Zhao Liang(startryst@163.com)
