Difference between ISR routers and cube
Kuldeep0790
Hi can anyone tell what are the difference between isr routers and cubes.
Vaijanath Sonvane
Cisco Integrated Services Router (ISR) is a hardware platform that provides many different features such as WAN connectivity, Security, Unified Communication and so on. Cisco Unified Border Element (CUBE) is one of the licensed feature of ISR and it is used for SIP Trunk connectivity with Internet Telephony Service Provider (ITSP) for voice communication.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
balaji.bandi
suggest reading this presentation which gives you clear idea of what is ISR (which support CUBE)
https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2019/pdf/BRKCOL-2125.pdf
BB
