10-06-2001 04:01 PM - edited 03-12-2019 12:49 PM
CCM 3.1.1 installed.
I configured the extension mobility as decribe in the manual.
When I try to make a login on the ipphone I reveive the login page, I fill it but nothing append.
I search in the trace of the CRA engine, I found this :
83: oct 07 00:24:38.822 CEDT %MIVR-APP_MGR-1-DFLT_SCRIPT_LOAD_ERROR:Failed to load default script: Script=null,Exception=com.cisco.wfapi.WFException: Failed to load application from the repository: null
84: oct 07 00:24:39.413 CEDT %MIVR-APP_MGR-6-SCRIPT_LOADED:Script loaded: Script=hotel.aef
85: oct 07 00:24:39.433 CEDT %MIVR-APP_MGR-6-APP_UNLOADED:Application unloaded: Application=login
I reade 5 times the notes to see what's wrong but nothing.
anyone have a idea ?
cheers
Armand
10-09-2001 08:55 PM
Have you tried stopping and starting the app engine? I have seen something like that before in the mivr.log but not with the Extension Mobility scripts.
Thank you,
10-19-2001 03:33 AM
I have exactely the same problem. I have Call Manager 3.1(2c). I restarted several times the app engine but no way. ???
11-21-2001 08:10 AM
Same problem here. Anyone have a fix yet.
11-21-2001 01:58 PM
Well, I just got a lot closer to getting it to work. Had to change the following lines:
In form.jsp
Object url = "http://"+servername+":"+serverport+ uri +"?devicename=" + name;
to
Object url = "http://"+servername+":8080"+ uri +"?devicename=" + name;
And in login.asp
xmlInput += "http://" + Request.ServerVariables("SERVER_NAME") + "/LoginService/LoginRequest.dtd\">\n";
to
xmlInput += "http://" + Request.ServerVariables("SERVER_NAME") + ":8080/LoginService/LoginRequest.dtd\">\n";
I actually have it trying to authenticate but I'm now getting Authentication failed because of an unknown error. But it is progress. Before it wasn't responding at all.
11-21-2001 01:59 PM
the problem is identified. in CCMadmin serive URL must be lower than 30 chars. Use IP address or NETBIOS name of the Extended services server running.
11-28-2001 05:43 AM
Thanks, but no that isn't the problem. I am using the ip addresses for the url. I'm still getting Unknown error from service.
11-30-2001 12:30 PM
Be sure you are using the default phone loads that come with 3.1(2c). Extension mobility does not work with phones that run SRST loads.
12-01-2001 06:17 PM
Maybe you´ve done this but try shuting down the CM Server and booting againg. I got a similar problem and stopping the services did not help. Luck
