Extension Mobility - Users not logged in
adancso
Can someone help me to solve the following:
I've configured EM feature according to the guide on the web.
May problem is that when a user selects Services/Login on the phone he/she can write any username/pin combination he/she will not logged in.
After pressing Submit a screen appears with "Please Sign On", there are only two options Update and Exit.
I'm using CM 3.1(3a) and Applications 2.2(2), I've integrated the CM with Active Directory, maybe it's relevant.
Thanks for the help,
Attila
mimckee
Take a look at the link below. It has most of the common extension mobility issues listed here. I think the one you are describing is in there.
http://www.cisco.com/warp/public/788/AVVID/extension_mobility.html
Thank you,
-Mckee
I had the same problem.
Reinstall the JTAPI-Plugin on your EM-Server (should be your Call-Manager).
You find the JTAPI-Plugin at the Plugin-Website at your Call-Manager.
Chris
