help with setting up wireless headset
nhaeussl
Hi! We were given cisco 8841 phone with our phone company for our business. I bought a cisco 561 headset and was hoping to use it but cannot figure out how to.  After lots of research, I think it will only work if I have the ability to log on cisco call manager?   The instructions I phone to hook up were this :
In order to use the Y cable with 78XX and 88XX phones, it is required to enable Wireless Headset
Hookswitch Control parameter in Call Manager.
Navigate to CM Admin > Device > Phone and select the phone. In the phone configuration page, look for
Headset hookswitch control and from the drop-down list select Enabled. Click on Save, and then click on
Apply config.
I do not have Call Manager to be able to enable wirless headset hookswitch control.   Can I use this wireless headset or is it useless????
With the setup you describe you should be using a phone with MPP software and on these the configuration is done on the webUI of the phone. For this you do not need to have a CM.
Response Signature
There’s no need for a CUCM, as the 560 headset is supported by the MPP platform. 8841 doesnt support USB in this case you need to use the Y cable which came along with the headsets.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/Headsets/Compatibility_Guide/n500_b_headset-compatibility/n500-m-cisco-ip-phone-8800-series-with-multiplatform-firmware.html#Cisco_Reference.dita_a0c962c6-eb36-42fa-98aa-2ac457dad106
Cisco Headset 560 Series
The Cisco Headset 560 Series can connect to the Cisco IP Phone 8800 Series through the included USB cable or Y-Cable.
The following tables contain information on the minimum phone and headset firmware versions that support the Cisco Headset 560 Series
Table 13. Minimum Headset Firmware
Headset Model
Minimum Firmware
Headset Firmware 1.5(1) or later
Table 14. Cisco IP Phone 8800 Series
Model
Minimum Firmware
Recommended Firmware
Connection
Cisco IP Phone 8841
Multiplatform Firmware 11.3(1) or later
Y-Cable
The following table lists the available headset features on the Cisco IP Phone 8800 Series.
Table 15. Cisco Headset 560 Series Features
Feature
Y-Cable
USB
Bluetooth
Answer and end calls
Yes
Yes
Yes
Hold/resume calls
Yes
Yes
No
Mute/unmute calls
Yes
Yes
Yes
Volume control
Yes
Yes
Yes
Adjust sidetone
Yes
Yes
No
Adjust microphone gain
Yes
Yes
No
Adjust equalizer
Yes
Yes
No
Reset settings
No
No
No
Headset upgrades
Yes
Yes
No
The following table lists the available Cisco Headset 560 Series serviceability features through the Cisco IP Phone 8800 Series Multiplatform Phones.
Table 16. Multiplatform Phone Headset Serviceability Features
Feature
Availability
Remote Firmware Upgrade
Yes*
Remote Configuration
No
Log Collection
Yes
Inventory
Yes
Headset Metrics
No
Response Signature
