Incoming/Outgoing problems
technology
Within the last 24 hours we have developed a slight problem with our CallManager. It does not appear to be affecting all users, or all calls.
Incoming calls will sometimes ring the phone, but when they answer the phone, there is nothing there. No static, just dead air. The Caller-ID string displays correctly.
Outgoing calls will dial, ring, and connect, but the caller hears nothing. The called party can hear the caller. If they hang-up and redial the call it might work fine.
I am on the same CallManager, and I have not experienced either of these problems. We have approximate 125 phones, and I have heard from less than 5 users.
We are running CM 3.13a. Gateway is a VG200 with IOS 12.2(4)T1. We have a 3640 router with IOS 12.1(5)T12. Uptimes are CM- 37 days, VG200- 22wks, 3640- 5 weeks.
I'm contemplating rebooting the CallManager server. It sounds like a memory leak to me. Anything I can look at to help diagnose a memory leak?
Thanks!
Steve
Madison Local Schools
adeolu_adeoye
Hi Steve,
Take a look at the link below. I hope it helps.
http://www.cisco.com/warp/public/788/AVVID/fix_1way_voice.html
Ade
Thanks for the link.
Steve
Sounds like a lack of configuration on the inbound dial-peer to state the codec to be used. i.e. "voice-class codec 1"
