IP Communicator not working with CCM v-3.1
tyagivijay
Our Cisco IP Communicator is not working with Callmanager v3.1, while other 7940 & 7960 IP Phone are working fine with it , please suggest some solution.
Vijay
2 Accepted Solutions
yavuzsab
Thats correct IP communicator will not work with CM 3.1. You will require minimum Callmanager version 3.3.3sr3 and above for IP Communicator to register and operate.
I really recommend that you upgrade your CM version to atleast 3.3(4) or above as you are running a very old Callmanager version release.
Cheers!
-Yavuz
You will need to contact your local cisco account team/manager or reseller and request the Cisco Callmanager upgrade CD kit 3.3(3) or 3.3(4) for your supported Cisco server inorder to successfully upgrade from CM 3.1 (SQL 7) to CM 3.3 (SQL 2K).
Yes, CM 3.3(4) "maintance" upgrade release is available on Cisco site. Its not the full CM installation and recovery .iso image. Only .exe.
Please refer to the URLs below.
Obtaining CM CDs.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_qanda_item09186a00802262ed.shtml
Upgrade procedures from CM 3.1 to 3.3
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/3_3/install/upgrade/index.htm
Note: You will require your CM server to be on minimum CM version 3.1(4)b inorder to upgrade to CM 3.3.X.
Cheers!
Yavuz
yavuzsab
Cheers!
-Yavuz
Hello Yavuz ,
Thanks for the info .
For 3.3(4) upgrade all the software are available on Cisco site ??
Thanks again
Vijay
Obtaining CM CDs.
Cheers!
Yavuz
Thanks a lot Yavuz.
