10-14-2002 05:31 AM - edited 03-12-2019 09:09 PM
I do want to set up SRST on the Gateway for failover suport of the Call Manager in the same LAN. Is it possible?
Which will be my problems in this configuration?
10-14-2002 05:50 AM
I don't think there will be a problem with this. It should not matter if it is the same vlan as the ccm or not. The thing it should try to open the default gateway when it cannot connect to ccm and the phone is configure for srst in ccm device config.
Thank you,
-Mckee
10-14-2002 06:10 AM
When the CM fail the gateway with SRST handle the phone, but what happens when the CM is alive again. Will the phone come back to CM?
Thanks in advance
10-14-2002 10:56 AM
When the ccm comes back, the phone will automatically goes back to CCM
10-14-2002 11:33 AM
How it works?
Thanks in advance
MP
