ISDN PRI without DID
I am trying to setup a PRI interface in Beijing they call the service 30b+1d it has only one number, ( DID is a different service) the follwoing is what I get from a q931 debug
Oct 28 15:42:33.913 AU-wint: ISDN Se0/2:15 Q931: RX <- SETUP pd = 8 callref = 0
x002D
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838E
Exclusive, Channel 14
Calling Party Number i = 0x0081, '13801286605'
Plan:Unknown, Type:Unknown
Oct 28 15:42:33.917 AU-wint: ISDN Se0/2:15 Q931: TX -> CALL_PROC pd = 8 callref
= 0x802D
Oct 28 15:42:33.921 AU-wint: ISDN Se0/2:15 Q931: TX -> DISCONNECT pd = 8 callre
f = 0x802D
Cause i = 0x8081 - Unallocated/unassigned number
Oct 28 15:42:34.009 AU-wint: ISDN Se0/2:15 Q931: RX <- RELEASE pd = 8 callref =
0x002D
Oct 28 15:42:34.009 AU-wint: ISDN Se0/2:15 Q931: TX -> RELEASE_COMP pd = 8 call
ref = 0x802D
had the normal dial-peer config, but didn't work
As you don't see any called number in the signalling I tried putting a "Connection PLAR" command on the voice port still no joy
anybody got any ideas
yshraybman
Level 4
Level 4
try debug voip ccapi inout. it might have more info that possibly can give you some clues.
