Mailbox for group of users
Hi all,
I have CUCM, Cisco Unity Connection, Contact Center Express. Contact center express is used for routing incoming call to group of agents, if there is no agent available then the call is routed to Voicemail. The agents need to be notified by MWI. Does anybody have an idea?
Thanks.
Jaime Valencia
Either configure a mailbox or a call handler and set the users who need MWI as notification devices.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Another option would be to use a Dispatch Message-style distribution list. This works particuarly well with call center-style departments.
