Manually reset FXO port
wilson_1234_2
Level 3
Level 3
How do you reset an FXO port?
8 Replies 8
paolo bevilacqua
In theory, shut / no shut in voice-port configuration mode.
Unfortunately there are certain "conditions", I would call these bugs, in which no maneuvering has effect, and the port is just stuck until the router is reloaded.
FXO are the most subject to these problems.
We have a B1 line that rings once and then goes to dial tone.
I have reset the FXO port and reloaded the router.
What could I look for to isolate if this is a line problem or our equipment?
Excuse me, what is a B1 line ?
What means, rings once then goes to dial-tone ?
Router configuration ? IOS used ?
A regular POTS line into the building that is using the FXO port?
when dialing the device that is on the remote site router FXO port, it rings once then you hear that it has picked up, it then goes to dial tone.
The router is a 2811, 12.4(9)
I can see the port go off hook when doing a "sh voice port sum"
I am not familiar with troubleshooting voice, I was just looking for some tips on what to look for
Have you resolved this issue? If not I would suggest looking into the router configuration. In addition to the voice-port configuration, you will also need a corosponding "dial-peer". I have seen situations when incomplete dial-peers are in the config ahead of the correctly configured dial-peer. When that happened I got the same symptoms -- one ring and then dial-tone.
Brian
Rob Huffman
Hi Wilson,
Just to add a note to Paolo's good info. The first thing to do is to isolate the Line from the equipment. Connect an Analog phone to the Line before it attaches to the equipment and see if the problem still exists. If yes/ then contact Telco provider (may be a problem often referred to a Ring-Trip), if No/ reconnect the Line and continue troubleshooting.
Let us know,
Hope this helps!
Rob
Thanks for the reply,
Is an FXO port then a port that will take regular POTS telephone signal and route it to an end device?
Hi Wilson,
Yes, that is a reasonable description. Here is another one (along with some other good info);
The Cisco Foreign Exchange Office (FXO) interface is an RJ-11 connector that allows an analog connection to be directed at the public switched telephone network's (PSTN's) central office or to a station interface on a private branch exchange (PBX). The FXO sits on the switch end of the connection. It plugs directly into the line side of the switch so the switch thinks the FXO interface is a telephone.
From this good doc;
Understanding Foreign Exchange Office (FXO) Voice Interface Cards
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800b53c7.shtml
Hope this helps!
Rob
