Mapping Phone Extension to FXO port -- CME Outbound Call
apmorgan
I have a 1751-V with CME and 2 port fxo with 2 pots.
On a 7960 with 2 extensions I would like to be able to map all outbound calls from extension 1 to fxo port #1 and ext2 to fxo#2.
As per: http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_configuration_example09186a00801bc341.shtml
I tried this, but doesn't seem to work.
voice translation-rule 2
rule 1 /^/ /2/
voice translation-rule 3
rule 1 /^/ /3/
voice translation-profile Line2
translate called 3
voice translation-profile Line1
translate called 2
dial-peer voice 22 pots
destination-pattern 2T
port 2/1
forward-digits all
prefix 1
dial-peer voice 23 pots
destination-pattern 3T
port 2/0
forward-digits all
prefix 1
dial-peer voice 1 voip
translation-profile incoming Line3
answer-address 3003
dial-peer voice 2 voip
translation-profile incoming Line2
answer-address 2002
8 Replies 8
anup.anand
Level 5
Level 5
For CME phones, the translations need to be applied on the ephone-dn's corresponding to the phone lines using the translate called command
ephone-dn 1
translate called 10
Also, CME does not support voice translation-profile commands. You need to use the old "translation-rule" commands.
Anup
Thanks for the reply.
I tried this:
rule 1 /^/ /2/
rule 1 /^/ /3/
port 2/1
forward-digits all
prefix 1
port 2/0
forward-digits all
prefix 1
ephone-dn 1
number 2002
translate called 2
ephone-dn 2
number 3003
translate called 3
but it still doesn't work.
Only calls started with a 2 or a 3 work.I hoped that my translation rule would prepend a 2 or 3 to any dial string and then match dial-peer destination pattern which in turn would forward to a FXO port.
Try these translation commands
translation-rule 2
Rule 1 ^% 2
translation-rule 3
Rule 1 ^% 3
It seems that the extension is not being mapped to the ports. The doc you referred to states:
Configuring the H323 Gateway Inbound dial-peers.
An incoming dial-peer in the gateway will accept an outgoing call from the Cisco IP Phone.
Thought it say's inbound it is still referring to an outbound call from the DN.
Unless I missed something you will need to add:
translation-profile incoming Phone1
answer-address 8378
!--- A call from Cisco IP Phone 8378 will match this dial-peer.
!--- The answer-address matches the ANI of the calling party, which triggers the
!--- translation-profile Phone1. This profile then prefixes a "1" onto the destination
!--- pattern so that the call can be sent out a specific FXS port.
Almost working...
It seems like destination-pattern 2T is not stripping the 2, so 9175551212 is being dialed as 29175551212, at least according to debug voice dialpeer.
To test I changed forward-digits all to forward-digits 10 and calls work because it takes right most 10 digits.
digit-strip is enabled on dial-peer.
Any ideas on why "2" remains in dialout number?
Thanks for your help
Andrew
patsbc
This is kind of tricky, and I've wanted to do something similiar. I think your voice translation-rules are mangled (or they are not being posted correctly by the forum). You are substituting all digits for the number 2, or the number 3 in your translation rules, versus adding the required correct digits.
This should take all digits and append the prefix correctly. Try this instead:
rule 1 /^\(.*\)/ /2\1/
rule 1 /^\(.*\)/ /3\1/
Let me know if you get it working. Have a good one.
Pat
rcfoltz
Level 5
Level 5
You can also use Class Of Restriction CoR for this. For example:
dial-peer cor custom
name port100
name port101
dial-peer cor list use100
member port100
dial-peer cor list use101
member port101
dial-peer voice 100 pots
port 1/0/0
corlist outgoing use100
destination-pattern 9T
dial-peer voice 101 pots
port 1/0/1
corlist outgoing use101
dial-peer voice 10 voip
answer-address 3000
corlist incoming use100
dial-peer voice 20 voip
answer-address 3001
corlist incoming use101
Now extension 3000 will use only port 1/0/0 and Extension 3001 will use 1/0/1. I'm lazy and I dont like messing with translations so this is the way I would take care of this issue.
Thanks -- implementation with COR is getting the job done.
