01-28-2005 08:56 AM - edited 03-13-2019 07:50 AM
Can a gateway have dial-peers that use a gatekeeper for call admission control to one gateway and dial-peers that don't but point to a gateway that uses a limited number of Ds0's for call admission control?
01-28-2005 11:43 AM
If you want to direct a call to use a gatekeeper for address resolution and call control you put in:
session target ras
In your dial-peer ... To send it direct to a gateway (therefore bypassing the GK) you would put
session target ipv4:192.168.1.10
You can also limit the number of calls that can go out on a particular dial-peer, in the dial-peer config mode there's a command which I can't quite remember but is something obvious like maximum sessions or maximum calls...
01-28-2005 12:49 PM
OK, that sounds good and it's what I was hoping to confirm. One specific on this, you can have a dial-peer on a gateway with session target ras and another dial-peer on the same gateway with session target ipv4:192.168.1.10 ? In the second case, my call admission control comes from the limited channels to the PSTN on that gateway.
Thank you,
Terry
