Port number for Attendant Console
dhcchan
Hi there,
I get an Attendant Console for receptionist in a data VLAN, while the pair of CCM cluster is in voice vlan. Access list will be applied in router voice vlan interface for protecting CCM cluster from virus attack. May I ask which port numbers will be used by Attendant Console to communicate with CCM cluster.
thanks a lot
David
erhoehne
Hi dhcchan,
Cisco CallManager Attendant Console and Interactive Voice Response (IVR)/Interactive Call Distribution (ICD) both use Remote Method Invocation (RMI) for communication. The default RMI communication port is 1099. If Cisco CallManager Attendant Console starts up before IVR/ICD, it binds to port 1099 first. However, if Cisco CallManager Attendant Console starts up after ICD/IVR is up and the port 1099 is already taken, it looks for the first available port after 1099.
I hope this helps!
Erik Hoehne
See the below link.This gives you all the applications and the ports used.
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a00801a62b9.shtml
Radhika
