Problem calling from CME to CCM
thack
I have a few sites running CME 4.0 and a couple of sites with CCM4.1. I would like to be able to call between CME and CCM. Calling from the CCM's to the CME's using an ICT works fine, but cannot call the other way. CME's can talk to each other though.
Tony
12 Replies 12
Chris Deren
Can you post your CME config?
Couple of things to make sure:
voip dial-peers are pointing to the correct IP address
The ICT trunk has CSS applied with access to phone's partition.
Chris
The dial-peer is pointing the to Pub,( have tried the sub but same problem).
The ICT has a CSS in which all partitions reside. Important parts of the config below:-
isdn switch-type primary-ni
voice-card 0
no dspfarm
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
fax protocol pass-through g711ulaw
h323
h225 h245-address on-connect
modem passthrough nse payload-type 101 codec g711ulaw
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class h323 1
h225 h245-address facility
h225 h245-address progress
h225 h245-address sync
call preserve
telephony-service ccm-compatible
ccm-compatible
dial-peer voice 4 voip
description (other CME site)
destination-pattern 25..
voice-class h323 1
session target ipv4:10.8.21.254
codec g711ulaw
no vad
dial-peer voice 3 voip
description (CCM 4.1 site)
destination-pattern 3...
voice-class h323 1
session target ipv4:10.9.200.1 (Pub)
no vad
codec g711ulaw
telephony-service
load 7910 P00403020214
load 7960-7940 P00305000301
load 7914 S00104000100
load 7961 TERM41.7-0-3-0S
load 7936 cmterm_7936.3-3-5-0
max-ephones 200
max-dn 200
ip source-address 10.8.97.253 port 2000
auto assign 1 to 200
timeouts interdigit 4
url information http://10.8.97.253/localdirectory
url directories http://10.8.97.253/localdirectory
url services http://10.8.97.253/localdirectory
url authentication http://10.8.97.251/voiceview/authentication/authentic
time-zone 8
voicemail 1755
max-conferences 12 gain -6
moh music-on-hold.au
web admin system name **** password ****
web admin customer name *** password ***
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
create cnf-files version-stamp 7960 Nov 02 2006 14:06:18
Tony
You need this configured
h323-gateway voip bind srcaddr x.x.x.x
Just like Junfeng said,
If your ICT trunk has 1.1.1.1 as the ip address configured, go under the specific interface in CME router with the same ip address and give the h323 bind command.
Sankar
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Guys,
It is already configured on the interface.
interface GigabitEthernet0/0.1
description DATA VLAN
encapsulation dot1Q 197
ip address 10.1.97.253 255.255.255.0
arp timeout 300
interface GigabitEthernet0/0.2
description VOICE VLAN
encapsulation dot1Q 897
ip address 10.8.97.253 255.255.255.0
arp timeout 300
h323-gateway voip bind srcaddr 10.8.97.253
Tony
You are missing this command under Gi0/0.2
h323-gateway voip interface
Also, you are forcing the codec to G.711 in the dial-peer, how is the trunk configured in CCM, what is the region referenced by the device pool configured to use between other regions? If it is G.729 the call will fail, unless you have a MRGL with transcoder applied to the Trunk (not device pool).
Your best option is to create voice codec class with codec preferences and apply to dial-peer.
Chris
gpulos
Level 8
Level 8
do you have the correct outbound dialPeers for calls from the CME to the CCMs?
please paste your config, minus any sensative IP addys, and we can better help you.
In the ICT configuration, do you have MTP Required Checked? If yes, can you uncheck that and reset the ICT and see if that helps.
Also how about the Enable Inbound Faststart check box?
Anup
yep, tried both them but no change.
I have run some traces, i can see the CME router matching the correct dial-peer, but the call does not reach the CCM's. From the CME router i can ping the CCM;s and the CCM registered Ip Phones. From the CCM I can ping the CME registered phones.
thanks
Tony
Have you tried nixing the ICT and making the connection an h.323 gateway instead?
Also you might try pointing to one of the subs just to see if it works. mtp and/or media resources might be screwed up.
Also try "incoming called-number " and see if that matches better.
****TRIED THAT ALREADY****
****NOT TRIED THAT. WILL GIVE IT GO.***
THANKS
TONY
Icoming called number 3040 (my ext) didnt make any difference.
thanks
Tony
