Recommendation on a Pharmacy IVR system that'll work with CUCM
Randy Calderon
I'm wondering if anyone out there has any recommendation on a pharmacy IVR system that will work well with CUCM. Was it a breeze to deploy or was it full of headaches? Any suggestions and recommendations are truly appreciated.
Thank you,
Randy C.
Gergely Szabo
Cisco's own UCCX.
Relatively easy to set up but you need to know what you want from it.
G.
Hello Gergely,
Thanks for taking the time to respond. .
We do have UCCX but we don't use IVR on it. This definitely would be a consideration. Do you know if UCCX IVR can work with our pharmacy's system? Say for example, a customer asks for a refill request of their medication using IVR by just entering the prescription number.
Also, what are the capabilities/limitations of UCCX IVR?
-Randy C.
Yes UCCX can be designed to do all sorts of things using DB dips (provided you have Premium licenses) or if you are using latest versions, using REST API calls.
Please rate useful posts.
