stop calls from cell phones to certain Ip phones
rbradfield
Level 2
Level 2
One of my users wants to stop people that use mobile(cell) phones from calling certain extensions. We are running standard Callmanager 3.3 using Router H323 gateways to the PSTN, I have had a quick look at COR but I don't know if that would do it
I need to be able to put check on the incoming calling number, then somehow stop it going to certain internal numbers
Anybody got any ideas.
gogasca
Level 10
Level 10
You might play with translation-rules in your H323
You might use an incoming dial-peer that matches CALLING PARTY NUMBER using answer-address command.
Then something like..
voice translation-rule 1 Assuming we only receive 1200 as called number..(1200 is our extension).
rule 1 reject /^1200/
voice translation-profile profile1
translate called 1
dial-peer voice 1000 pots
answer-address 9788587088 <--- Calling number
translation-profile outgoing profile1
direct-inward-dial
port 1/0:23
http://www.cisco.com/warp/public/788/voip/voice_transla_rules.html#reject
