Truncate called number using translation rule
tpaprotny
I have a Cisco 2851 router and I need to chop off the first digit in the incoming
called number string (e,g 272109 translate to 72109).
I have tried using rule 1 /^.*\(..\)/ /\1/ but I cannot get this to work, keeps saying it is an incomplete command.
Can anyone help please
Brandon Buffin
Are the numbers always the same length? If so, you can use the following rule to keep the last 5 digits.
voice translation-rule 1
rule 1 /^.*\(.....\)/ /\1/
Hope this helps.
Brandon
paolo bevilacqua
rule 1 /^./ //
Remember: what is unmatched, stays unchanged.
