UCCX licensing in BE 6000 solution
Mammad Mammadov
Hello!
Whether need a license CCX-11-CR-LIC  in solution BE 6000 with CCX promo bundle in integration with MediaSense or is it included?
Manish Gogna
Hi Mammad,
Entitled Cisco partners can raise such queries with the partner helpline team at the following link
http://www.cisco.com/c/en/us/partners/support-help/presales-helpline.html
You may engage your Cisco Account team for more details.
Manish
Deepak Rawat
CCX-11-CR-LIC is for Compliance Recording functionality AFAIK however it is still advisable to check with PH suggested by Manish. CCX integration with MS does not require any licensing as MS is RTU however if you have plans to record UCCX agents then you will need to have Unified CCX recording license purchased and installed on CCX.
Deepak
