Unable navigate between 2 active calls on 7931G
Hello ,
I have a problem with ip phone 7931G .
I'm unable to switch between 2 active calls .I respond at the first call , when respond the second call the first going in hold state and there is no way to hold the second call to resume the first .
When the second call end the first call come available .
The system is 2801 with IOS Version 12.4(11)XW22801-SPSERVICESK9-M the 7931 FW is SCCP31.8-2-2SR2S .
Thanks .
Hi Leonardo,
Sorry about that! This is a limitation of the 7931G Model itself :(
Hope this helps!
Rob
5 Replies 5
Hi Rob,
I have already see the solution posted , but i need know if the problem is the limitation of the phone or the funcionality of the phone is the same of the other model (7941 and 7911)
Thanks .
Hi Leonardo,
Hope this helps!
Rob
andresfmg
i have the same problem!! did you find any solution ?
by the way the link its broken
Hi Andres,
Here is the reference
https://supportforums.cisco.com/message/1101872#1101872
Cheers!
Rob
