10-31-2007 05:10 AM - edited 03-13-2019 04:38 PM
Hi, I am having issues. All my VIC2-2FXO and VIC2-4FXO are picking up, then hanging up right away. I tried them on 1760s and 2811s. I tried a combination of supervisory disconnect, but can't get it to work. On 1760s, if I put a VIC-2FXO in the place of the VIC2-2FXO it works just fine. Is there a special command needed for VIC2s???
Solved! Go to Solution.
10-09-2010 07:35 AM
Please help to advice how to configure an FXO port on a router to able to give the dialtone
Here is a snippets which i thought would have done that
voice-port 0/1/1
timeouts call-disconnect 2
timeouts wait-release 2
caller-id enable
and for dialpeer
dial-peer voice 2 pots
preference 1
destination-pattern .T
port 0/1/1
forward-digits all
The FXO connects to the legacy PABX and can make the outbound calls. when the legancy dial the number that connects to the 0/1/1, it doesnt give dialtone but only disconnect
Please advice
Sam
10-09-2010 10:16 AM
Please open new thread for new problem.
01-21-2014 05:31 AM
I'm having the same issue and I have tried the command but no use. Here is my thread any thoughts you can share would be greatly appreciated:
10-20-2016 10:41 AM
Hello Paolo,
I think you should show us the output of the debugs command for ok FXO calls and for not ok FXO calls, so we could understand how they work on a gateway.
