09-17-2009 01:04 PM - edited 03-13-2019 06:39 PM
I just earned my CCNA-voice and I would like to set up a lab for next CCVP. any cheap set up or any afordable setup that I can use. I am asking for your opinion
09-21-2009 01:30 PM
Packet Tracer is a good Virtual Lab setup that is pretty accurate.. Look into the latest version of that.
10-02-2009 05:47 PM
I have run CME via GNS3 successfully and also installed CUCM with VMWare. These are both free options. If you want hardware then you will need to shop around on ebay, etc..
Did you pass CCNA Voice without any lab?
10-21-2009 12:30 AM
I am interested in voice labs. Could you explain your voice labs?
08-06-2010 03:58 PM
The best way will be using VMWare, GNS3, CIPC that its the cheapest configuration that you can have to practice for the CCVP exams, regarding labs the use you imagination try to do everyhing that you can find in books and more .
Please rate this post if was helpful
Walter Solano
CCVP
UCCX & Communications Express Specialist
08-06-2010 08:54 PM
There is a excelent solution to you practice ccvp lab remotly. Take a look the website:
http://www.cisco-voicelab.com/
I grant my CCVP using the above website.
Thank you
