10-08-2012 03:07 PM - edited 03-01-2019 07:11 AM
I have 1 NX5K & 1 NX2K (FEX) and configured PIM on them -Release 5.2(1)N1(1).
I configured on the NX2K's ports the ip igmp join-group command to statically bind a multicast group to an interface. The multicast PIM works fine but when I try to remove the ip igmp join-group command on any interface because not all should have this command, I cannot.
I have not found any bug on the 5.2(1)N1(1) version related to this behavior and the released notes not mentioned anything about this.
Any ideas...!?
-Sergio
10-09-2012 07:57 AM
Hello Sergio
FEX ports are meant to be L2 ports only and hence you should not be allowed to configure "ip igmp join-group" but looks like we do allow it which is a bug.. I will see if there is one filed for it and if not file a new one.
-Prashanth
10-09-2012 08:20 AM
Hello Sergio
I have filed a new bug CSCuc58233 for this
-Prashanth
10-09-2012 08:35 AM
10-09-2012 12:22 PM
Hi Sergio
New bugs take 48-72 hours to be visible on Cisco.com
-Prashanth
12-05-2012 02:47 PM
