% Deleted all L3 config on interface Vlan on Nexus 7K (OS 5.1)
Parmanand Patil
Hello Folks,
I tried creating L3 on Nexus 7K & got message "% Deleted all L3 config on interface Vlan136" there was no existing vlan 136.
Is it standard behivour in Nexus ?
X7K01(config)#
7K01(config)# vlan 136
7K01(config-vlan)# name Dev-136
7K01(config-vlan)# exit
7K01(config)# interface Vlan136
7K01(config-if)# vrf member Ext
7K01(config-if)# ip address 10.20.136.2/22
7K01(config-if)# hsrp 136
7K01(config-if-hsrp)# preempt delay minimum 180
7K01(config-if-hsrp)# priority 103
7K01(config-if-hsrp)# timers  1  3
7K01(config-if-hsrp)# ip 10.20.136.1
7K01(config-if-hsrp)# no shutdown
PSP
Steve Fuller
Level 9
Level 9
This is the standard behaviour when configuring an interface as part of an existing VRF. As per the Guidelines and Limitations section on page 6 of the Configuring Layer 3 Virtualization configuration guide:
VRFs have the following guidelines and limitations:
  • When you make an interface a member of an existing VRF, Cisco NX-OS removes all layer 3 configuration. You should configure all layer 3 parameters after adding an interface to a VRF.
I may be wrong, but I'd imagine this is to ensure that configuration or addressing from one VRF could not accidently be introduced into a different VRF if you move an interface from one VRF to another.
Steve Fuller
Level 9
Level 9
Looks like you are correct, Thanks for your response !!!
