Is N7K-F312FQ-25 module hot swappable/online insertion supported?
As titled.
Can't find any documentation confirming whether is or not. Datasheet says nothing about it.
Wes Austin
Yes they are hot-swappable. All N7K linecards can be swapped while N7K is online.
You can replace each of these I/O modules with another module of the same type while the Cisco Nexus 7000 Series switch is operational. To do this action, you must first remove an I/O module from the chassis, and then install a new or replacement I/O module in the newly vacated slot within a couple of minutes to maintain the designed airflow.
Wes Austin
