Access lists problem in Cisco 801
kaustavcisco
I recently configured a Cisco 801 with a scenarioas follows:
Router 801 is connecting to the internet via easy IP configuration. The dialer 1 is getting the IP from the ISP ,BRI 0 has no ip address , NAT is on. I have given a access-list standard .The configurations I made are included below:
Username: ÿÿalh1
Password:
alh1>en
Password:
alh1#sh run
Building configuration...
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname alh1
logging buffered 8192 debugging
enable secret 5 $1$zonS$nWY3EbiPDzsxALwNAQIsA/
username alh1 password 7 1511021F07257A
ip subnet-zero
no ip source-route
isdn switch-type basic-net3
interface Ethernet
interface Ethernet0
ip address 128.127.20.121 255.255.0.0
no ip directed-broadcast
no ip proxy-arp
ip nat inside
interface BRI0
no ip address
encapsulation ppp
dialer pool-member 1
ppp authentication chap pap callin
ppp multilink
interface Dialer1
description ISP
ip address negotiated
no ip proxy-arp
ip nat outside
encapsulation ppp
no ip split-horizon
dialer remote-name Cisco1
dialer idle-timeout 300
dialer string 0803630000 class DialClass
dialer string 0803631000 class DialClass
dialer hold-queue 10
dialer load-threshold 10 either
dialer pool 1
dialer-group 1
pulse-time 0
ppp chap hostname alh1isdn
ppp chap password 7 047F3927280E621F5B
ppp pap sent-username alh1isdn password 7 1536392D230505757A
ppp multilink
ip nat inside source list 18 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
map-class dialer DialClass
access-list 18 permit 128.127.0.0 0.0.255.255
dialer-list 1 protocol ip permit
line con 0
exec-timeout 120 0
transport input none
stopbits 1
line vty 0 4
exec-timeout 0 0
login local
I tried to put in the access lists single hosts like
access-list 18 permit host 128.127.20.1
for 5 hosts only removing the access-list 128.127.0.0 0.0.255.255 for controlling the internet access. The interface was found to be not dialing to the ISP ..
What can be problem any help?
jduffek
Well if your router is not dialing we shouldn't worry about ACLs, unless they are applied to your dialer-list...which they are not.
I would run:
config t
service timestamp debug datetime msec
access-list 150 permit icmp any host 1.1.1.1
end
sh ver | i IOS
sh dialer int dialer1
sh isdn stat
sh int dialer1
debug dialer
debug ip pack 150
debug isdn q931
debug ppp nego
term mon
ping 1.1.1.1 (should be already routed to dialer1)
When you ping 1.1.1.1 the ios *should* route the packet out your point-to-point dialer1 interface. Then it will look at dial-group/list 1 to make sure it is interesting traffic, which it is, so this should bring up a dial. Then isdn should tx a setup for the number in your first dialer string. Which will then also, do nothing becuse your map-class dialclass has nothing in it. Then you should eventually get a rx connect and tx a connect ack, all at the q931 layer. After that ppp will try to negotiate and your ddr code should automagically bind the call to your only dialer profile, should. PPP should negotiate multilink and an authentication protocol. Then LCP will open. After that we move to authentication, if there is aaa on the NAS side we might have to look at how that is working. If authentication succeds then we move to NCP. We should send IPCP config requests(IPCP: O CONFREQ address: 0.0.0.0, or something like that). If the peer naks that request with a proper address for us to use and we agree with what they are using on their side ipcp should open. Then, proper routing and nat should work....that is another bunch of processes I don't want to get into because that is not the problem at hand(looks configured right to me).
Debug ip nat if not...
12.0 might not have certain bug fixes that you need...just a thought.
Josh
Thanx,
I shall check into what u said.. I shall get back to you in need.
Regds/
kaustavcisco
